so from the looks of it thats the right place.
to answer your question. you have a 95% chance of getting it fixed. its going to require solder work and using jump wire and solder mask to fix those messed up solder pads.
that requires running jumper wires from the last good area the trace is at. no offense but probably a bit past the skill level you currently have.
a shop like northridgefix on youtube would be able to repair this for you.
if you wanted to try and do this your self its going to require a bit of gear.
soldering iron with a micro tip and solder and flux
solder wick
jumper wire and probably solder mask
a razor blade and fine tipped tweezers. the list goes on lol
so what i would suggest is to look up the price for a repair shop to do this and then look up the price of a decent webcam if you even need one and go from there.
if you dont NEED the webcam….. there really is no harm in just not putting it back in. BUT IF YOU DO THIS, please make sure u cover the end of that connector with some electrical tape so if it does move around in there once reassembled it doesnt short anything else out in the area!
i hope this helped.
good luck!
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
