Ana içeriğe geç
The Smart Oven® with Element IQ® is a trustworthy tool for the cook who wants a countertop oven that roasts succulent meat, broils, bake pizza, reheas leftovers and toasts evenly. Convection setting reduces cooking time by up to 30%. Model: BOV800XL
24 Soru Tümünü görüntüle
Convection fan hums but doesn't turn.
The convection fan isn’t turning when trying to use the convection setting on the Breville toaster oven. Motor hums (60 Hz I believe) when trying to turn. Everything else works fine. Heating elements, display, etc.
Convection fan turns freely by blowing pressurized air across blades with power off or convection setting off. The fan will continue to spin for 30 seconds or more.
If the fan is spun initially and the convection function is then turned on, the fan quickly slows and stops.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
6 Comments
Have you ohmed it out? Check the motor for specs and check amp draw. Might have bad windings on it.
tarafından
Will do, if I can get to the motor. From what I've seen on the web, these things are a bear to take apart. Apparently, a really long screwdriver is needed to reach from the back to the front at some point.
tarafından
Opened it up and was able to get to the motor. Resistance was 150 ohms. Looked for specs (SDR5812-01A15 120V 60Hz 15W). Only thing I was able to find was that this part is no longer available on a couple of repair websites.
Turned motor several times by hand, no real resistance. Noticed some play (~1mm or maybe less) where shaft can go in and out. Pushed and pulled along axis and turned motor. Noticed some minor scraping from the fan blades inside the oven (couldn't see these). Assumed it may be crud and did it a few more times and the scraping decreased.
Put motor straight to 120V 60Hz. Motor turned no problem. Put everything back together and now it works.
Motor does make a low, dull knocking sound when turning (not tinny like the fan blades are hitting something). Don't really know if it was doing this before.
I suspect the bushings are going bad and the "fix" is only temporary. Guess I'll start saving up for another one.
tarafından
@cbhuffman very odd... normally bearings go (screeching/grinding/whining sounds) or fan is hitting something... sounds you described is very 9dd indeed. And yeah I can't source a motor n either. And it is such a strange looking motor i can't think of one that could be used in its place.
tarafından
My son bought us this one in 2019 - fan died in just over a two years. The Delonghi I threw away was still working after over 15 years. Oh well.
tarafından
1 tane daha yorum göster
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @cbhuffman,
For what it’s worth the fan motor part number is Breville part # SP0010500.
I’ve searched online without success as all suppliers state that it is no longer available from the manufacturer. You may have better luck.
There is always trying the donor parts option perhaps, i,e, search online for a faulty oven but having a different problem, if you consider it’s worth taking the risk on the fan working OK and the price suits. Just a thought
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
the YJ58 is an oven fan rated at 220/110v with the exact same specs! you are welcome people!!!
LONG LIVE THE 800XL!!!
Puan 0
2 Comments:
Has anyone tested the YJ58 as a replacement part? Our 800XL just did the fan death harry carry...
tarafından
There are 4 different versions of the YJ58.
Can anyone confirm the exact model number?
tarafından
Yorum Ekle
From your efforts, it sounds like the fan was hanging up on that "crud". Just do a good cleaning to totally eliminate that "dull knocking sound". The fan runs fine outside the unit - so it has to be interference making the noise.
Update (12/24/2022)
That fan doesn't have a starter capacitor on it, does it?
Puan 0
Yorum Ekle
I had the same problem. I completely removed the motor and took out the 2 screws holding the motor together. I found that the bushings were not worn at all, but the oven side bushing was loose. There's ring "clip" holding the busing in place. The clip looks like an inside out flower (pedals facing inward instead of outward). I applied some pressure on opposing pedals with a pair of needle nose pliers to reseat the busing and tighten it up. That removed all play in the shaft. After reassembling everything the noise was gone and the motor no longer stalled.
Puan 0
1 Yorum:
can you show a photo of where the 2 screws are? i took off the cover, i see the fan from the outside, but i don't see any access to the fan facing the inside. i do notice that something that was holding it up was loose but not sure where that holder is at
tarafından
Yorum Ekle
Same here. This is my second, and there will be no third for me. It's time to move on. There are better companies out there.
Puan 0
Yorum Ekle
Yanıtını ekle
Chad Huffman sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 57
Son 30 gün: 263
Her zaman: 6,261
