Total pain in the butt... i ordered a jy58 motor.. 220v unit.. and will attempt to merge the 2 motors together to make 1 working unit. The 'clips' are not able to be attached.. so im going to transplant them from a 220v motor to the original 110v windings. https://www.amazon.com/dp/B0987TMX53
and the verdict is... yes, it can be done... and yes, the frankenstein motor works.. with a few notes:
.25) Be EXTREMELY careful. the covers are razor sharp.
.4) Have a torch handy. The screws on the sides of the fan blade hub are frozen solid, torch the hub for 15 seconds to loosen the Allen screw.
.5) take pictures as you disassemble the unit. Better yet, wait to disassemble until donor motor arrives. 1-2 weeks introduces a lot of mistakes when reassembling
.75) The screws holding the endcaps on... wet with acetone before trying to take apart.. otherwise, they will NOT come apart. they used some type of Lock-Tite in the threads that makes it a PITA if you don't soak with solvent.
1) The endcaps/bushing mounts don't fit. you need to (I used a stair step drill-bit) drill to open the magnetic winding core so the endcap alignment protrusion fits, after a minor drilling, they clicked right into place. Stair-step bit will auto center.
2) The center core needs to be swapped between units. The above motor doesn't have the external fan shaft for cooling the control board
3) the core doesn't match the same size. using the spare washers from the donor core, you can space them correctly. If you are still front to rear sloppy on the shaft, ace hardware carries nylon washers that fit. I bought 4 washers, I think I only used 1.. maybe 2. (23 cents apiece)
4) Be slow at disassembly and careful handling the motor core.. my unit is like 8? years old and the insulating plastic is brittle as all heck..
Did I mention to take pictures.. take A LOT of them....
reassembling the endcaps with the original core, don't use the new core's screws.. the motor wont fit if you try. The screws are too long.
The endcaps are NOT universal. Place the endcap with the threaded screw holes on the long shaft side of the motor.
Don't be afraid of sharpie marking panels as you disassemble.
Don't miss-place the spacer washers between the metal plate, insulating pad, insulating plate, and motor (take a lot of pictures)
If you need to step away and scream.. do so.
when the wife says "is it on? It isn't making that grumbling/buzzing noise anymore", smile.
Note: the original motor had a defective design. The new motor endcaps are crimped to not fail in the same way.
Note: if when re-assembling, the cover wont fit (right side).... the fan blades face INWARD.... /facepalm
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
2
6 Yorum
Have you ohmed it out? Check the motor for specs and check amp draw. Might have bad windings on it.
brandon k tarafından
Will do, if I can get to the motor. From what I've seen on the web, these things are a bear to take apart. Apparently, a really long screwdriver is needed to reach from the back to the front at some point.
Chad Huffman tarafından
Opened it up and was able to get to the motor. Resistance was 150 ohms. Looked for specs (SDR5812-01A15 120V 60Hz 15W). Only thing I was able to find was that this part is no longer available on a couple of repair websites.
Turned motor several times by hand, no real resistance. Noticed some play (~1mm or maybe less) where shaft can go in and out. Pushed and pulled along axis and turned motor. Noticed some minor scraping from the fan blades inside the oven (couldn't see these). Assumed it may be crud and did it a few more times and the scraping decreased.
Put motor straight to 120V 60Hz. Motor turned no problem. Put everything back together and now it works.
Motor does make a low, dull knocking sound when turning (not tinny like the fan blades are hitting something). Don't really know if it was doing this before.
I suspect the bushings are going bad and the "fix" is only temporary. Guess I'll start saving up for another one.
@cbhuffman very odd... normally bearings go (screeching/grinding/whining sounds) or fan is hitting something... sounds you described is very 9dd indeed. And yeah I can't source a motor n either. And it is such a strange looking motor i can't think of one that could be used in its place.
My son bought us this one in 2019 - fan died in just over a two years. The Delonghi I threw away was still working after over 15 years. Oh well.
larry ciummo tarafından
1 tane daha yorum göster
