Ana içeriğe geç
4 Kasım 2017'de satışa sunulmuştur. Model A1865, A1901. GSM ya da CDMA olarak 64 ya da 256 GB kapasitelerinde, Gümüş ya da Uzay Grisi renklerinde satılır. ("iPhone 10" olarak da telaffuz edilir.)
1199 Soru Tümünü görüntüle
How come the replacement screen I bought doesnt match my phone?
I have an iphone x and was trying to replace my screen. On the left is the screen i received - it seems to have support brackets all the way around and does not fit my phone. However, my original screen does not have these brackets and is flat all the way around. Does anyone know what my problem is + why my iphone x seems to be different than the normal one?
Update (05/30/2021)
if this is the correct screen…how are these tabs supposed to fit into what looks to be a flat bracket covering?
Update (05/30/2021)
also comparing other iphones online, mine looks to be a bit different with this top area as well? anyone know whats going on here?
Bu iyi bir soru mu?
Puan 0
1 Yorum
How did you remove the old bezel from the phone?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I think it snap of of the original screen and sit stuck in the housing, take a look if the part is still left in the housing and take it out.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
You’ve torn the bezel off the screen, normally it doesn’t happen, usually it happens with phones that are heavily corroded by sweat, or you’ve got a non-original screen to begin with, the bezel wasn’t attached to the screen securely on those screens.
Puan 2
2 Yorum:
@Spencer Lott you still have the bezel on the phone, pull it off.
tarafından
you are the man
tarafından
Yorum Ekle
Yanıtını ekle
Spencer Lott sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 24
Her zaman: 448
