Ana içeriğe geç
Repair guides and technical knowledge for the Xiaomi Mi Mix 2, released in 2017.
12 Soru Tümünü görüntüle
How can I check whether my charging port is broken? (Xiaomi Mi Mix 2)
Hello there!
I have a problem with my current Xiaomi Mi Mix 2. I does not charge. I suspect that the charging port is the cause of the problem since I have had problems with it before.
My question is how can I check whether the charging port is really broken or if the problem is somewhere else.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The easiest way would be to buy a little USB Amp/Volt Meter and plug it into the wall and then your charger cable into that and it will let you know if the charger is drawing amps or not. If not it’s most likely in need of being replaced.
The meters are less than £5 if you look around…
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
BugReport Plon sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 142
