Why does my freezer door trigger my fridge light?
I have a GE Monogram ZISB420DHC French Door Refrigerator. When I open the fridge door the light inside does not come on. But if I keep the door open and open the freezer side door, then the fridge light will come on. I'm not sure which part to replace or how to fix this.
Bu iyi bir soru mu?
3 Yorum
Hi,
Do the refrigerator lights stay on after you have opened the freezer door, if you leave the refrigerator door open and then close the freezer door or do they go out again?
Try opening the refrigerator door and if the light doesn't come on, gently "tap" the refrigerator compartment door switch which is located in the door jamb to see if it now comes on.
I'm wondering if it is a faulty door switch or perhaps a loose connection on the door switch and the vibration when the freezer door is opened is enough to make it work again.
What have you tried?
jayeff tarafından
I tried what you suggested and the freezer door seems to turn the lights on and off. When I open and close it.
Toi Truong tarafından
Oh and I trier the tapping method on the switch and nothing happens.
