Ana içeriğe geç
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
Home button and touch id not responding
whilst cleaning charge port 99% isopropyl alcohol must have seeped into the phone opened up and well cleaned and dried phone powers back up but lost touch id and home button function HELP… tryed heat gun all over phone but no luck
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
try opening and checking the home button. it may need to be cleaned or to be connected properly.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Try disconnecting then reconnecting the screen ensuring the connectors go on properly. There are 2 connectors in the middle right side of the screen, the Home Button connector one is the smaller, shorter lengthened one.
if that doesn’t work, make sure the home button connector is attached to the screen, it’s under the home button plate.
Finally there’s a chance you could have damaged the flex cable that connects the home button to the screen. You can try installing a new screen on.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
oliver crancher sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 47
