Ana içeriğe geç
Ocak 2020'de piyasaya sürüldü; SM-A015F, SM-A015F/DS, SM-A015G, SM-A015G/DS, SM-A015M, SM-A015M/DS, SM-A015T1, SM-S111DL, SM-A015V, SM-A015A model numaralarıyla tanımlanır.
How do you remove the back cover?
I bought a new phone yesterday and need to put my old SIM card in the new phone but I can’t figure out how to remove the cover.
Thank you
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 7
Yorum Ekle
8 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @holliee,
Here’s an image taken from the user manual that shows what to do.
Resim
(click on image to enlarge for better viewing)
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
Hi,
When the phone is facing you, the SIM tray card is on top right hand corner area. It should have the SIM and SD Card tray with it.
Hope that helps.
Puan 3
Yorum Ekle
Remove the sim card tray and pry off the back cover which aint easy. 2 small screw drivers and then pry around. If it wont charge try this first. On a Q-tip dipped in alcohol hold the phone upright and swab out the charge port. After cleaning allow it to dry. Thoroughly dry ! After it is dry hold it upright & brush it out with a soft brill tooth brush. Take your time, don’t compromise. Holding it upright allows all the debris to fall out. Charge it, if Lightning shows charging on screen Ok if not consider a new phone.
Puan 1
1 Yorum:
I have a Samsung galaxy ao1 core and my headphones are paired with the phone but the phone has been charging all day and now will vibrate and screen will flash but not turn on I just want to unpair my headphones from the phone and now can't, how do I fix this?
tarafından
Yorum Ekle
Sim tray is on side above power button. Release it pull it out replace sim and return. If you still need to remove cover pry apart only with sim tray removed. Start from the sim tray with pry tool giving a slight twist open at every point that hasn't pried
Puan 0
Yorum Ekle
The SIM card holder tray on the A01 is above the power switch. No need to remove the back.
Puan 0
Yorum Ekle
There's a small hole on the side for something like a pin, insert something small enough and that's where you place the sim card and micro sd card
Puan 0
Yorum Ekle
You don't remove the back the side has a small hole that you put the sim ejector tool into push in and the tray will pop out you can then face your sim card down.
Puan 0
Yorum Ekle
Tech stak my answer
phone plese
Puan 0
Yorum Ekle
Yanıtını ekle
Holly sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 24
Her zaman: 4,850
