Ana içeriğe geç
In this video playlist you can find all repair guide of Sony Xperia XZs, include Battery, LCD Screen, Rear Camera etc.
Black screen after display replacement even though the touch works
My screen cracked a few days ago so I bought a new battery and screen. The new battery works fine but the new screen stays black. When touching the screen I get feedback sounds/vibration.
I had the phone running with the broken screen for two days so i still could use whatsapp on my pc, the white backlight still flickered sometimes while it was on.
The old screen is completely destroyed and only came off in 100 pieces.
And the screen stays black regardless of the battery. Everything else works I guess.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
Turn on the phone and then try shining a torch at an angle close to the screen and check if you can see images at all on the screen.
They will be very faint if they are there so trying this in a darkened room may help to see them.
If you can then you have a backlight problem.
It could be in the new display (faulty unit), a blown backlight fuse on the systemboard (was the battery disconnected before reconnecting the new display?) or another problem on the systemboard.
I couldn’t find the schematics for your model but here’s a link showing the backlight fuse location for a Xperia XZ2 that may help. Hopefully it may be the same for your model. Xperia XZ2 backlight fuse.
As a DIY repair all you can do if it is a backlight power problem is to check if there is backlight power going to the display i.e. fuse OK and if so replace the display.
If there is no backlight power at all then you would need the schematics for your model to find out what’s wrong.
If it is not a backlight power problem and there is no display at all then you could try another display and check if that works (faulty first replacement?) and if still not working then it is a systemboard problem.
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
Thank you a lot, the Flashlight trick worked.
A new screen is coming and I also bought the same phone used off ebay for cheap and I'll try to repair it.
tarafından
Yorum Ekle
Try to force reboot your smartphone this will solve your problem.
https://okadtech.com/sony-xperia-z5-blac...
Check it this will help you in solving this problem.
Puan 0
Yorum Ekle
Yanıtını ekle
Hazgebu sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 37
Son 30 gün: 200
Her zaman: 9,521
