Ana içeriğe geç
Nest'in 3. nesil öğrenen termostatı. 1 Eylül 2015'te piyasaya sürüldü. Model numaraları: T3007EF, T3007ES, T3008US, T3010FD, T3010GB, T3016US, T3017US, T3018US, T3019US, T3021US, T3032US.
How to drain battery
The iFixit instructions with the replacement battery says to charge, drain, and charge. Does anyone know how to drain the battery in a consistent way and how long does it take to do so. Obviously, reconnecting the thermostat back to the base won’t work since it can charge from the base.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @sscollis ,
Try disconnecting the power from the base.
As to how long it takes would depend on how much charge the battery has and what the load current is. I don’t know the answer to this.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
If you disconnect the "C" wire (probably blue) it will probably drain. Might take several days and inevitably will die at 2 am when it's 95 degrees out and you will wake up in a hot sweat! Personally I think that whole "memory" thing with batteries is left over from old NiCAD batteries and likely unnecessary for this application.
tarafından Paylaş
@nicksartor Nowadays the charge/drain instructions are not for the benefit of the battery "memory", but rather for the sake of battery health calibration to establish a full/empty baseline for monitoring the battery charge.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Sam Collis sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 33
Her zaman: 999
