Ana içeriğe geç
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
Facing No Service Freqently
Hi Team ,
i am facing No service Frequently ,
let me know if any solution available ,
the thing is i asked many technicians but they are not giving any guarantee instead of that they are saying that it may dead if they do any thing,
please let me know any possibility there to get it repair done ,because its gifted by mother since i am using this mobile from 4 years ,no repairers instead this only one issue,
Thanks in advance
Bharath.A
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If you've tried resetting network settings or completely wiping the device and the issue is still persisting, then it is likely a failure on the hardware side and you should get a reputable repair shop to diagnose the problem. Usually this will be done by a professional under a microscope, and they'll be able to tell what the issue is and how much it'll be to fix(if possible at all). Back up your data and try to identify if it's software related first though, however if it isn’t, it'll be a bit trickier and more expensive to fix unfortunately.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
i Tried it several Times Liam ,But No use ,can you suggest anyone who will be able to resolve the issue ,
Basically i am from india ,if they will repair it, i can ship my mobile to there place
tarafından
@avulabharath Here is a link I found through about 2 minutes of googling, however you could probably spend a little bit more time searching to find a better or faster service.
https://www.irepair.in/irepair-doorstep-...
tarafından
Hi Liam Thanks For Your Information ... I will Follow Up
tarafından
Yorum Ekle
Yanıtını ekle
BharathReddy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 90
