I replaced the clutch now it will not start cranks does not turnoveres
I replaced the clutch on 2004 rx8 6 speed
It cranks now but will not start.
Bu iyi bir soru mu?
Puan
0
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 58
any issues before the clutch change or just a routine change?
jay tarafından
No issues aside from burnt clutch
John Barrett tarafından
does it crank over at all the engine or is there no signs of life?
jay tarafından
I know a clutch job can be quite involved depending on the vehicle but did you check to make sure everything was connected?
Jesse Hooton tarafından
If it does not crank at all I would look at clutch safety switch. If it does not crank. Check to see if you have spark. And check to see if you have fuel pressure. Some times the wire running to fuel pump is near tranny. And can get pinched or cut while removing
GKJarhead tarafından
