Ana içeriğe geç
How can I secure this nut in place?
Hi, this nut came off of my laptop. As a result, the screw in this place can’t be secured and that part comes out when I open the laptop so i have to hold this place whenever i adjust the monitor’s angle or it will pop of. how can i secure this nut in place? thank you
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
You may have to remove the hinge assembly and check where the nut is seated and see if it can be glued back in place.
Maybe try a neutral cure sealant as some “super glues” etc may react badly with the plastic etc where the nut is housed.
Here’s the maintenance and service guide for the laptop, taken from this webpage.
Go to p.72 onwards to see how to remove the display assembly etc to gain access to the hinge mounts. You may have to remove the systemboard (see p.70) from the case as well.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Thanks so much for the effort and advice. i'll try my best and see if my ability can do this. thank you so much.
tarafından
I've never seen a successful repair for a palmrest break like this, especially when it's a high stress critical screw. Maybe it'll hold short term with a repair but I wouldn't be too quick to trust it long term.
It's just gonna need a new palmrest assembly.
tarafından
Yorum Ekle
Usually when ABS plastic breaks like this, you can’t salvage the part and it breaks again. I’ve tried before and it never seems to fix, at least long term. In your case, you’re between a rock and a hard place. The keyboard is part of the palmrest so you need a upper case assembly, which increases the cost to repair the laptop, and it’s not practical to remove the keyboard and try and salvage the situation - you have to replace both, in practice (to add insult to injury on the Consumer machines, it doesn’t serve any benefit besides feeling spiteful). The other problem is being an HP Consumer machine, this happens more often then the other vendors (although, yes they all seem to have issues on the consumer side with this, and it’s a pretty common design flaw). This is not as bad on the Commercial notebooks - especially with the magnesium service panel which acts as part of the hinge mechanism to prevent this to some degree.
This is the design in a Lat 7490*, by the way:
Dell’s design ain’t perfect either, nor is HP’s Commercial fix for this but it's still an upgrade even if it doesn't have the full magnesium chassis anymore. However, both of them have better overall hinge durability. The catch is it means if you’re dealing with a non-captive screwed system like the 840 G3, you need to give screws to the left and right top holes and leave another hole that’s not critical empty OR it does put the palmrest “at risk” of damage.
*If you want one, make sure it has the 8th gen CPU (Ex: i5-8XXXXU) rather then 7XXXXU. Thankfully, the 7th gen option isn’t horribly common BUT you need to check. Don’t buy this model if the seller is unsure because they’re not fully disclosing it to limit your recourse**, or have no knowledge of the specs (and need someone to at least look over the installed CPU). If the service tag is hidden, assume hidden 7th gen.
**The photo one is missing the M2x3 trackpad button screws (which I had on hand), so it feels like an abandoned project to me - especially with the missing battery/cable - (knowing Dell, probably expanded). I had enough information I wasn’t worried about it due to the CPU (i7-8650U).
It may work to bide your time while you save for a newer computer if you are considering a new system in the future (or at least, time to find a replacement upper case assembly), but I would not rely on a part repaired in a critical area like thing long term, especially with super glue or Epoxy unless it’s a low stress/non critical screw.
Puan 2
2 Yorum:
oh is that so... still, thanks for taking the time to comment! it still helped me @%^!* what things i can and can't do. thank you so much!
tarafından
@Angelo Curio Maybe Epoxy will help, but I'd still consider it a temporary repair. Plan to replace the laptop, or parts.
Added some photos of a proper design
tarafından
Yorum Ekle
Yanıtını ekle
Angelo Curio sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 94
