Ana içeriğe geç
Televizyon kumandaları için onarım ve söküm kılavuzları.
Fixing a water/coffee damaged remote
retail plus HDMI media player
Hi all,
I had bought a retail plus hdmi media player. It works okay for avi files and that is about it. My 1 year old grabbed the remote and used it as a swizzle stick in my wife's coffee. Now the remote is non responsive.
I have contacted the manufacturer through their web page but they are not responding to my inquiries.
What can I do to bring the remote back to life?
Bu iyi bir soru mu?
Puan 16
19 Yorum
I had a cup of water and my roku tv remote slid off my cover and fell in to the cup of water we tried to blow in it and blow dry it even new batteries and it doesn't work can u help me plz
tarafından
My daughter used me remote as a pee pot and now it's not work in what do I do the back doesn't open and I can't see and visible batteries help!!!!
tarafından
What can I do to get my fire stick remote to work after water got in i
tarafından
Today I spilt a full cup if coffee over my Sky remote and TV remote. Neither worked after that so I removed the batteries, heated up my oven and once the oven was hot I switched it off. I then wrapped the two remotes in a towel and put them in the oven. After a couple of hours I removed them from the oven, put the batteries back in and both remotes are now working
tarafından
My fire stick remote fell in water what do i do
tarafından
14 tane daha yorum göster
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
Use this guide to try to save it: Electronics Water Damage
Bu yanıt yardımcı oldu mu?
Puan 22
7 Yorum:
Ty it worked
tarafından
Glad it worked ;-)
tarafından
My romote want work after my 2 year old done put water in it
tarafından
@kaymilz89 take the batteries out, open it up and dry it out. Follow the link to the guide I posted.,
tarafından
My remote won't work find out it got weto 2 days ago can it be fix?
tarafından
2 tane daha yorum göster
Yorum Ekle
I was soaking my feet in my foot spa and the remote control fell in the water so what I did was turned on my heater and put the remote control in front of it not too close took the back of the remote off including taking out the batteries and took a shower when I was done I was ready for bed the remote or again
Puan 7
4 Yorum:
How do you dry out a wet remote control
tarafından
Submerge the wet remote into a rice bag and cover it with rice. Take and dust it after half a day and use it
tarafından
what if you didn't add it right away will it still work
tarafından
A mere drop of coffee shorted out my remote! Took a matter of maybe 5-10 mins . Removed batteries and back. Could see the obvious moisture from a drop of coffee. Sorta gently patted it Dy and than hair dryer on cool for 5mins. Popped back together, batteries in and voila'
tarafından
Yorum Ekle
Take out the battery and warm up a sock full of rice. Put the remote in the sock. Keep it there for one hour. It should work by then .
Puan 2
5 Yorum:
Hi @lizzzzzzzz ,
This may be of interest to you.
Don't Put Your Device in Rice. Here's Why...
tarafından
I try that but i think i didnt wok :/ or maybe i did it wrong
tarafından
this worked!! thank you sm
tarafından
great fix! Thanks so much for your advice
tarafından
I put rice in the sock then put it in micro wave took it out after one min put remote in sock allowed 30 min took it out put my batteries in, and voila the happiest person in the world.
tarafından
Yorum Ekle
Hello there, just try to open the remote and put it to dry ander light or sun, otherwise yiu can use a special drier usually it is used to work with smart phones, or clean it with isopropyl alcohol,
Puan 0
Yorum Ekle
Hello everyone, my extensive experience is as follows.
TL;DR I really truly hope this helps folks not freak out if they drop their precious phone into the water. It’s the spilling of coffee or lemonade ( sugared liquids ) that can, and will, severely damage non-shielded wiring inside consumer electronics. For water, use rice or low-humidity + high-heat to dry the device fully once batteries are removed. Otherwise, Rubbing Alcohol + air dry with buttons down.
1) Almost all water and / or soap & water mixture only is safe for almost all home and general office electronics.
Resolution 1) Remove the batteries first and foremost. Leaving the batteries in could possibly short the entire device out. Rice is the most natural way to extract moisture from devices. However, any very low-moisture + high relative heat will also yield the same result.
2) Caustic liquids( orange, cranberry & lime juices; some cleaners, bleach ) or liquids containing any amount of sugar ( high-fructose corn syrup, many coffee additives, retail teas and lemonades, milk ) are capable of rendering boards with non-shielded wiring inert. You may have to consider the device a total loss. This is a sad and sobering event.
Resolution 2) Find a container that is small in diameter, as close to container the device when it is vertically oriented. Fill this container with common Rubbing Alcohol ( Isopropyl Alcohol ) to cover the last buttons when the device is placed upside down, still vertically oriented, into the container. If this is done while the liquid is still a liquid then simply swishing the device around in the container should yield a great result. However, if the liquid has solidified ( or set ) any, then we will need to leave the device in the container with the alcohol for at least half an hour. We may then proceed with swishing in container until the desired result is achieved. Air dry with the device’s buttons facing down over a thin cloth. You may have to shake the device to free any remaining alcohol from hidden crevices inside.
2) Problem: This type of liquid causes instant damage to internal wiring, the type of damage and extent is variable.
2) Problem Symptoms: If the device behaves abnormally, or in an unpredictive manner, I herby stand to sincerely apologies for the state of your device. It is a total loss. There is no way to recover from this, unless you can solder monofilament, amongst other required talents, only some of which I possess. I have had to order several remotes and I have suffered the severe depression of learning that model is no longer produced and no remotes were made once the product was discontinued. This was a crushing blow to my inner peace.
Puan 0
1 Yorum:
Hi,
Rice is for dinner, not repair
tarafından
Yorum Ekle
Yanıtını ekle
Andy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 18
Son 30 gün: 96
Her zaman: 228,819
