Ana içeriğe geç
Always enter into boot mode whenever I open it...
Whenever i open my laptop it goes into boot mode and when I exit it it shows write protected and hardisk not attached but I have a hard disk in it .It is showing the above picture when I go into bios.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
When in BIOS, look through the BIOS menus and check that it shows that it has detected the HDD.
If there isn’t a HDD listed in BIOS you need to check if the HDD is connected OK. Can you hear the HDD spin up when the laptop is first started?
Here’s the hardware maintenance manual for the laptop. Go to p.46 to view the necessary pre-requisite steps and then the procedure to remove the HDD. This will allow you to check if it is connected OK and also if you can hear or “feel” it spinning.
If the BIOS does show the HDD then perhaps the HDD boot information is missing or corrupted. Here’s a link that may help with this.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Sir pls visit that pic once.
tarafından
@Satyam Singh
Try updating the BIOS from a USB flashdrive and see if that works
tarafından
Yorum Ekle
Bu cevap aslında başka bir soru için verilmişti.
I had somethinig similar. What helped in my case was "Load BIOS defaults"...
Puan 0
Yorum Ekle
Yanıtını ekle
Satyam Singh sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 18
Son 30 gün: 61
Her zaman: 1,503
