Ana içeriğe geç
Repair guides and support for your Samsung TV.
2614 Soru Tümünü görüntüle
Subtle flicker in tv backlight
Hi, I have a Samsung UE40H5303AK television which has a subtle flicker in the backlight. The leds go up and down slightly in brightness and from what I’ve seen the flickering becomes less severe after having the TV powered on for some time (although I’m not sure). I’ve measured all the pins on the PSU when on and off and it seems to be working perfectly and so does the main board. Could this be a problem with a capacitor or maybe a diode on the PSU? the only pin I haven’t measured is the BLU_PWM so maybe the main board is sending an unstable PWM signal. I’ll try to measure it with an oscilloscope and see if I see anything strange.
one more thing to add, backlight voltage across D+ and D - is around 120v and I have multiple broken leds on the backlight (one of the three strips only has 1 led working!)
Any help would be greatly appreciated.
Bu iyi bir soru mu?
Puan 0
1 Yorum
On further testing, I found that the backlight PWM voltage reaches 3.5v at max brightness. Is this normal as I believe this should be 3.3
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @stuig,
I suggest that you replace the backlight LED strips or replace all the faulty LEDs and then check if the backlight stays on without the flickering.
Other LEDs may also be on the verge of failing and this may be causing them to cause variations to the current flowing through them affecting the brightness.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Thank you, I'll try that.
tarafından
Yorum Ekle
Yanıtını ekle
Nvidia sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 29
Her zaman: 345
