Ana içeriğe geç
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
How to remove stuck (stripped/damaged patch/thread) screws?
Hi,
I was trying to replace the speakers of Macbook Pro A1398 following this guide MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement and I’m stuck at step 31.
I’m unable to remove one 2.6 mm T5 Torx screw (red) and one 5.8 mm T5 Torx screws (left orange one) due to their screw patch (thread) is damaged.
Is there any possible way to remove them using any tool? Any help would be highly appreciated. Thank you.
Best regards,
Arif
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You should be able to replace the right speaker as the screws holding it are exposed.
Are you using the proper sized screw driver, is yours worn? I would get a fresh tip/driver to see if that solves the problem. You also need to press down a bit Make sure you open the display so it is hanging over the edge of your work table and have something to pad the keyboard (thin towel or sheet of real chamois leather)
See if a scrap of chamois leather can help in getting a good bite with your driver. I also find a small drop of solvent around the screw head can sometime help and in other cases a soldering iron heating the screw can also help.
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
Hi Dan,
Thank you for the tips. I used a new T5 but there’s no grip. May I know where can I find a soldering iron to heat the screw?
Regards,
Arif
tarafından
@arifk - Something like this should do it Soldering Iron 60w Hakko 503F
tarafından
@danj, thank you very much. Appreciate it. Let me try out the methods you mentioned.
tarafından
Yorum Ekle
Yanıtını ekle
Arif Khan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 281
