Ana içeriğe geç
Lenovo's 1st generation convertible 2-in-1 laptop in its ThinkPad X1 line with a 14" touchscreen that pairs with included stylus pen. Released in 2016 with model number 20FQ00****
new battery still shuts down when ac power is unplugged
laptop shows battery charge is at 100%. when I unplug the ac power the laptop immediately shuts down even with new ifixit battery. ive tried several different ways to reset it. looking for more suggestions.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
Just to verify that the battery is OK, create a battery report to check it status.
Compare the Design Capacity value against the Full Charge Capacity value. With a good battery they should be nearly the same.
Does it do this if you reconnect the old battery again?
Bu yanıt yardımcı oldu mu?
Puan 1
8 Yorum:
I did a battery report. It checked out okay. The capacity values were nearly the same. But with the old battery, the computer would pop up a screen that said the battery was bad and needed to be replaced. It did the same thing to where it would shut off immediately after AC power was unplugged.
tarafından
I'm suffering from exact same.
# upower --show-info /org/freedesktop/UPower/devices/battery_BAT0
vendor: ifixit
model: bq20z451
power supply: yes
updated: Tue Jul 23 12:32:35 2024 (0 seconds ago)
battery
present: yes
rechargeable: yes
state: fully-charged
energy: 50.1676 Wh
energy-empty: 0 Wh
energy-full: 50.1676 Wh
energy-full-design: 53.2 Wh
voltage: 5.679 V
charge-cycles: 49
percentage: 100%
temperature: 28.2 degrees C
capacity: 94.3%
technology: lithium-ion
Whenever I unplug the charger, laptop dies instantly. As the battery is "100%" full, it won't charge.
It seems, there is no option to limit charging into 80% or similar. Also, it wouldn't help as the battery won't discharge from 100%.
tarafından
@hqjatu
Try uninstalling the Microsoft ACPI- Compliant Control Method battery driver in Device Manager and then restarting the laptop to allow Windows to reinstall it again and check if this resolves the problem.
To get to Device manager in Win10/11 press the Win key + x key (both together) and click on the Device Manager link.
When in Device Manager go to Battery → right click on the Microsoft ACPI- Compliant Control Method battery entry → Uninstall this device and follow the prompts and then restart the laptop in the normal manner.
tarafından
Just to be crystal clear:
Running a upower --show-info /org/freedesktop/UPower/devices/battery_BAT0 as root should point to correct direction of operating systems. Hint: non-Windows
So, unfortunately I cannot try that suggestion.
tarafından
@hqjatu
Try the suggestions in this link
tarafından
3 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
anthony samsel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 41
Her zaman: 1,394
