Ana içeriğe geç
Sony WH-1000XM2 kablosuz, gürültü engelleyici kulak üstü kulaklıklar için onarım ve söküm bilgileri.
Left speaker not working
Hi,
My left speaker stopped working. Touch is still working on the left side, right speaker works fine.
Can anyone advise which cables I should check/replace and Mark them in the attached image?
Resim
I have opened up the headphones.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum
Does the left speaker not work on wired mode(3.5mm cable), wireless mode(Bluetooth), or both?
tarafından Paylaş
It doesn't work wired and unwired
tarafından Paylaş
Hello,
Had the same issue with left speaker no longer working (after crackling for a few weeks),
The continuity of the wires was OK, however there is no continuity in the speaker itself once disconnected from the electronic board.
Do you know where to find a replacement speaker for hw-1000m2 ?
tarafından Paylaş
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
This sounds like a connection problem or a bad speaker. Can you take the circuit board and any protecting plastic off the left speaker cup?
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
I should be able to do that. What should I look out for?
tarafından Paylaş
@mrvolcan Make sure there are 2 wires connected from the speaker to the board. Make sure both of the wires have continuity from one side to the other. If both of those pass, comment both checks passed.
tarafından Paylaş
I have the exact same problem. This evening the left speaker if my sony wh-1000xm2 decided to stop working. I don't know what to do.
tarafından Paylaş
Yorum Ekle
I assume it is an connection problem between the pcbs on both sides. I have the same problem now with my headphones. I seems like there is no signal for the left driver. Anybody figured out the problem?
Puan 0
Yorum Ekle
Yanıtını ekle
Moritz sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 19
Son 30 gün: 50
Her zaman: 2,071
