Ana içeriğe geç
The Huawei MediaPad T3 7 Android tablet was released by Huawei Technologies Co., Ltd in October 2016 as part of the MediaPad series. The Huawei MediaPad T3 includes model numbers BG2-U01, BG2-W09, and BG2-U03.
6 Soru Tümünü görüntüle
Replace the charge port
The charge port on my tablet is ..pooched, for lack of a better description. The pins are wrecked. Can the port be replaced?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
The USB charge port (supplier example only) can be replaced but you will need smd (surface mount device) soldering skills and tools to do it. There are videos on YouTube that show how to remove/replace smd type USB connectors.
Here’s a teardown video that shows how to open the tablet so that the systemboard can be removed, allowing the removal/replacement of the USB port.
The supplier linked above was just to show you what the port looked like and how much they can cost. There are other suppliers online that may suit you better. Just search for Huawei Mediapad T3 7 usb charge port connector to get results.
Note: Be aware that not all micro USB 2.0 ports are the same. The pin connections are all the same but where the mounting lugs are positioned on the outer case of the USB connector can vary. The number of mounting lugs can also vary as well. These lugs have to match up to the tabs on the pcb so that they can be soldered there, so that the connector is securely mounted and the strain is not placed solely on the pin connections. That is why it is important to get the correct one for your model tablet.
If doing all this seems too daunting, contact a reputable, professional mobile phone repair service and ask for a quote.
Bu yanıt yardımcı oldu mu?
Puan 4
1 Yorum:
Thank You SO MUCH!
tarafından
Yorum Ekle
Yanıtını ekle
Sir B sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 1,230
