Ana içeriğe geç
6,01 inç AMOLED ekrana sahip bir Android akıllı telefon olan OnePlus 5T için onarım rehberleri ve destek. Kasım 2017'de piyasaya sürüldü. OnePlus 5'in devamı niteliğindedir. Model numarası: A5010.
Replugging screen : upside-down and multiple
Hello !
I just received a new screen to replace my broken OnePlus 5T screen. I thought it would be easy game : dissemble, plug and done.
However, the result is not quite what I expected. The screen is upside-down and displays two times what should appear once (as you will see attached). Also : the touch screen is at the right place, as if nothing was different from a new phone with perfect display…
Have I done something wrong… ? Do you have any solution?
Many thanks in advance !
Resim
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
KasDing the only thing you want to check on is your connector. Make sure that the pins are straight and not bend sideways etc. Ultimately this sounds and looks like a bad screen. Return it to wherever you bought it from and request a new display.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
Hello oldturkey03 !
As you said something could have been wrong with the pins, but surely the screen was down.
I returned it and got another which works perfectly :)
Thank you for your help !
tarafından Paylaş
KasDing glad it worked out for you! Keep on fixin'.....!!!
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
KasDing sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 21
Her zaman: 532
