Ana içeriğe geç
The Lenovo Yoga C930-13IKB is a 2-in-1 laptop that features a touchscreen, fingerprint reader, and tablet mode. The device comes with a Lenovo Active stylus pen, 65W AC adapter, 4 cell 60WHr Li-Polymer battery, and a quick start guide.
9 Soru Tümünü görüntüle
Both of my USB C ports now no longer charge laptop.
Both of the USB C ports on my laptop no longer have a solid connection when I plug in my charger. The charger used to have a “click” when I plugged it in, and now it doesn’t do that and the cable seems loose. I can’t get a steady charge from the cable on either port. I’ve tried multiple laptop USB C chargers, so it’s not the cable. Are the ports repairable?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @nachokingp ,
Both the USB-C ports are hard mounted on the systemboard, so you will need smd soldering skills and tools to replace them.
Visually inspect the ports, using a strong light and a magnifying glass to check if you can spot a problem either with the pins or the port enclosure.
If there appears to be dust or lint etc in the enclosure, that may be preventing a good electrical connection, do not use a metal pin or probe to try and extract it, use a vacuum cleaner instead to try and suck it out.
Here’s the hardware maintenance manual for the laptop. Go to p.46 to view the necessary pre-requisite steps and then the procedure to remove the systemboard as this will need to be done to replace the connectors.
If doing all this seems too daunting, contact a reputable. professional laptop repair service and ask for a quote.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
Brian Remite sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 790
