Ana içeriğe geç
Repair and disassembly guides and support for dish washing appliances.
707 Soru Tümünü görüntüle
Dishwasher is draining slowly and not completely draining
I’m having the same problem with my Kenmore series 665. I’ve replaced the drain pump, motherboard and float switch. I’ve cleared the drain line. The unit worked fine for 4+ years, and now will not drain completely during the cycles. It will drain if I press the cancel button multiple times. Did you ever figure out the problem? If so, please let me know, I’m on the brink of just replacing the whole machine. Thanks!
Model #66515113K216 Kenmore dishwasher
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @paulieboi ,
Here’s a link to the tech sheet for the dishwasher.
It details how to run the diagnostics for the dishwasher to check for any error codes. If any error codes appear, it describes the most likely cause and what to check
Hopefully this is of some help.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Thanks @jayeff for the info. I had found that on the tech sheet, and have ran the diagnostic after each repair, but doesn’t give me any error codes.
I think I’m going to resign to just getting a new machine, rather than spend any more time and money on this one.
tarafından
@paulieboi
OK.
Final check maybe is to check the OWI as per p.3 is OK.
It does a check during the drain mode (interval #5)
I think that the OWI may be known as the turbidity sensor
tarafından
Yorum Ekle
Yanıtını ekle
Paul sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 53
