Ana içeriğe geç
Aquos LC-13B2UA, Sharp tarafından üretilen bir LCD televizyondur. Sharp Aquos LC-13B2UA, 13x3 inç boyutlarındadır.
Plugged in and popped
Plugged in and popped, now doesn't turn on. We found out that all our outlets in our basement were getting too much power. I haven't attempted to fix, figured TV was done. I thought this site might give me some answers. I have no problem taking it apart if it can be fixed…is it worth it or a lost cause?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @cindylee ,
Just verifying that the TV is an LC-13B2UA?
If so, looking at the user manual for the TV it has an AC/DC power adapter which supplies 12V DC power to the TV.
If the power outlets were supplying too much power the adapter may have failed and not the TV.
Plug the adapter into a power outlet only and check if there is 12V DC when measured on the output plug of the adapter.
If the adapter output voltage is OK you have to remove the back cover from the TV and inspect the board where the power plugs into. Check for a blown fuse or surge suppressor (images to show what they look like) near the power input or other blown components on the board.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Cindy Houston sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 343
