Ana içeriğe geç
8.2 mega pixel point and shoot camera.
Why cant I turn on my camera
when i try and turn on my camera i will not be able to push that botton because its stuck.
Bu iyi bir soru mu?
Puan 4
1 Yorum
We are having the same problem. One day the camera was working fine then it just locked up. It seems that the on off button is not responding. We have changed the batteries but it did not help
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Follow this guide up to step 10 and see if the actual button has been dislodged. Once you have gone that far, check the switch without the cover and see if you can "feel " it click. Check for the plastic button in the cover and see if it cracked, broken or if you can loosen it. Hope this helps to get you started
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
My lens is showing error.My lens is not closing.
Puan 0
Yorum Ekle
Yanıtını ekle
smithtamara69 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 31
Her zaman: 7,401
