Turns on, Windows loads then freezes.
And sometimes everything will load up, but when you click on something, it begins to make a repeatative mouse clicking noise.
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
Before re-installing anything,
you should start in safe mode and try to troubleshoot the problem.
On Dell computers, you simply have to press F8 when the computer is starting.
A menu will offer you to start in safe mode.
Are you up to date in terms of Windows XP security updates?
If no, you should start there.
http://windowsupdate.microsoft.com
Did you try with another mouse?
If you don't have another mouse, did you look on your mouse provider's help center if there is such a problem described and solved?
Is your mouse driver updated?
Do you have an anti-virus?
If yes, please run a full scan.
If no, you can install a free anti-virus like Avast, Microsoft Essentials or Avira AntiVir.
http://www.avast.com/free-antivirus-down...
http://www.microsoft.com/security_essent...
http://www.free-av.com/en/index.html
Please provide any information you can. It might help.
Bu yanıt yardımcı oldu mu?
Find out what OS you are using and re-image it. If this doesn't work it could be a hardware fault, most likely logic board. (or mother board as you PC users say)
You can try running a your anti-virus program and your malware program. Before running them boot into the safe mode. Have you recently installed new software? If so consider uninstalling it. Another possibility would be to use a restore point from before the problem started. If all of these fail backup what you can and reformat the drive and reinstall XP. Good luck Ralph
If you backup and restore I would virus/malware check my backup before reinstalling. Ralph
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 12
Her zaman: 1,643
2 Yorum
Which OS are you using? Ralph
rj713 tarafından
Windows XP
Tristan tarafından
