No coffee or water coming from the dispenser
Hello,
I have a Saeco Royal Professional, it was working fine.
When I power the machine on it comes ready.
When I press the coffee button, the machine goes through the whole cycle and there are no unusual sounds.
There is no water or coffee coming out of the dispensing unit.
The grounds end up in the container (dry) and the hot water goes to the drip tray.
Please see link below:
I have the same machine and with this exact same issue.
https://www.youtube.com/watch?v=EP1OKPf3...
Your advise will be appreciated.
Thank you in advance.
Bu iyi bir soru mu?
Have you tried using coffee that is more finely ground? Has this.xoffee worked in the past?
Andrew S tarafından
Hi Andrew, thank you for replying.
Yes, been using the same beans for years and the same setting.
Regards
learner2info tarafından
