Ana içeriğe geç
Ford Explorer ve Mercury Mountaineer'ın her ikisi de, Tower Automotive yerine Magna International tarafından üretilen yeni bir çerçeve üzerinde 2006 model yılı için güncellendi.
AC only blowing heat
My blend door actuator started clicking and was stuck on AC. I finally just replaced the actuator and now I have heat but I now only have heat. No matter what I set the temp setting to it just blows hot air out of all the vents on both sides, driver and passenger.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
i have ford explorer model 2010. same issue of no cold air blowing
checked and found compressor clutch relay not energizing. while jumping he clutch relay contact ,compressor clutch engaging. seems some control logic blocking the signal to compressor clutch relay. anyone can suggest what are the signals blocking the compressor clutch from engaging?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
I would guess that there is still a problem with the blend door.
If it were “clicking” I would think the actuator was attempting to move the door, but something was wrong with the drive.
Or it could be that the actuator did not get installed properly.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
My only guess is there is something wrong with the new actuator. My setting was already set on cold so it started blowing hot before I messed with it. I’m not sure how it could be installed incorrectly. There is only one plug and the shaft only fits in one way.
tarafından
Did you fixed the issue? Because I’m having the problem too
tarafından
Yorum Ekle
Yanıtını ekle
Scot Williams sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 33
Her zaman: 1,287
