Ana içeriğe geç
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
20 Soru Tümünü görüntüle
Why is my laptop overheating?
I have a:
  • MacBook Pro (Retina, 15-inch, Early 2013)
  • 2.8 GHz Quad-Core i7
  • 16GB Memory
  • 768GB SSD - 26% is available
  • NVIDIA GeForce GT 650M 1 GB and Intel HD Graphics 4000 1536 MB
The fans go on max for the simplest of demands, like surfing the web. The CPU Cores get extremely hot very easily. If I edit a video on battery the device will get so hot it turns off.
I have:
Changed the thermal paste
https://www.amazon.co.uk/gp/product/B011...
Changed the battery
https://store.ifixit.co.uk/products/macb...
Sprayed the inside with an air duster
https://www.amazon.co.uk/gp/product/B000...
Changed the left and right speakers - This was due to them not functioning
Changed the trackpad - This was due to it no longer clicking
What would you suggest I do in order to prevent the system getting so hot?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Let's install this great app! TG Pro so we can get better view of things. Take a snapshot of the main app window but first adjust its size so all of the sensors are visible (not needing to use the right hand slide) in one window and post it here for us to see when things are running on the hot side Adding images to an existing question
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Bu cevap aslında başka bir soru için verilmişti.
I noted the CPU temps seem high given the lower temps at the heat sink fins. I’m thinking your heat sink has failed. When you where cleaning did you done any oily spots on the logic board where the heat sink tubes pass or see any white dust stuck along the tubes. MacBook Pro 15" Retina (Late 2013-Mid 2014, Integrated Graphics) Heat Sink and MacBook Pro 15" Retina (Late 2013-Mid 2015, Dual Graphics) Heat Sink as well as the guide MacBook Pro 15" Retina Display Late 2013 Heat Sink Replacement
This part attaches to the processor and helps dissipate heat. Görseli
Ürün
$19.99
Ürün
$19.99
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Did you actually remove the motherboard? There is a few screws that hold the heat pipes and fin array to the motherboard. these have to be just tight enough to not allow it to back off. Also if it did come off somehow you probably just need to replace the thermal paste after you clean off the old paste. the old paste dry’s out and if the “seal?” is broken almost never reseats well enough without replacing it. clean old stuff off with alcohol and qtips. Also check the fins around the outside of the fan. These can get a layer of dust that you can’t just blow out and sometimes requires manual removal.
also when you put on the heat sink each screw should be about the same tightness. if even one screw is to tight you will only have a partial connection. You should also tighten in a cross or star pattern so you have the same tightness on each screw.
My guess is that you have one side to tight so the other side of the heat plate doesn’t get down enough.
Puan 0
1 Yorum:
Yorum Ekle
Yanıtını ekle
Tazer Presland sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 185
