Ana içeriğe geç
Miposaur is a robotic dinosaur made by WowWee in 2015 and its model number is OKP0890. This guide will provide resources for and information on repairing a broken Miposaur.
5 Soru Tümünü görüntüle
Battery holder is corroded
Battery holder is corroded can I get replacement
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Can you not clean it of corrosion? A small metal brush should be able to clean all the corrosion from the batteries out, and then it should be fine.
I haven't been able to find anyone that has the battery cartridges in stock. You could always change it to a rechargeable battery pack. Wowwee's website has those in-stock.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
mix some baking soda with water and using a q-tip dab it and rub off the corrosion. when you get it clean than apply some dielectric grease and it shouldn’t corrode again at least not for a very long time.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
June Page sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 51
