Ana içeriğe geç
Smove mobile battery replacement
I need to replace the battery on my Smove Mobile gimble device it is a Howell 2x902360-1300mah 7.4v 9.62wh battery I need to find a suitable replacement either the same battery or an except-able replacement. I’m fine with soldering the terminals if I can find the same form factor battery.
Resim
Resim
Resim
Resim
Resim
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum
I am curious if you found a good solution for this?
tarafından
@grayraver See oldturkey03's answer
tarafından
How did you get the SMOVE apart? I have the same issue and want to bring mine back to life
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You can tape two of these together and solder the batteries onto the wires coming out of the connector in the same way the old batteries were connected to the connector.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Do i need to connect with a parallel connection?
tarafından
On SMove pictures it shows 7.4v battery, so it looks like we need to connect two 3.7v batteries sequentially.
But connector shows 4 wires - 2 red and 2 black. Does connector actually connects them sequentially?
tarafından
Yorum Ekle
@starsoldier420 pretty common battery pack on RC equipment. You should easily find a replacement at sites like this. All you would need to modify might be the connector.
Puan 0
Yorum Ekle
Yanıtını ekle
Randy Northrup sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 25
Her zaman: 1,464
