XBR-55X900E Four red blinks.
My tv developed a problem where it will power on and the shut down. Once shut down it blinks red 4 times. It will power back on and then does the same thing. I have replaced the bmks board and ld board. Any insight as to what is going on? Also if anyone has the capacitor layout for the bmks board that would be helpful. The service manual has two listed but i cannot find a diagram.
Bu iyi bir soru mu?
2 Yorum
I've developed the same repeating 4 red blinks issue on my unit. went through all the soft & hard reset attempts with the tv at first giving me a start up ("SONY & Android letters then red flashing again) have replaced the main (BMKS) board with no change. Can you confirm that the LD IC board is the LED Driver board as I'll try that as well.
WiscDon tarafından
My Sony XBR55X9005E TV has a malfunction, after a few hours of operation it blinks four times.
I tried a factory reset from the TV menu, I tried a reset from the buttons on the TV, power and volume down, when the green led appears, but in both situations the problem persists.
It works for a few hours, then it goes into error, I turn it off and sometimes it works for a while, and in some situations it stops working, it flashes 4 times continuously.
The codes on the LED Driver board are: LD35/ 0081223/ A2166063A/ PKG1001/ SSV/ A4/ 1700329A.
What can the TV have?
Thank you.
https://imgur.com/a/r41M4am
Saimarica tarafından
