Ana içeriğe geç
PlayStation 3 (veya daha sık bilinen adıyla PS3), Sony Computer Entertainment tarafından üretilen üçüncü ev bilgisayar eğlence sistemidir ve PlayStation 2'nin akabinde devamı olarak üretilmiştir. 11 Kasım 2006'da piyasaya sürüldü.
781 Soru Tümünü görüntüle
PS3 FAT YLOD symptoms?
Hi everyone, i have a fat PS3 (CECHC04) that worked fine until a few months ago. I swap the HDD years ago with a 250GB one and i had no issues. I haven't used the console much lately, it has been shut down for a month or more, i don’t remember exactly.
I tried to turn it on a few days ago, the light turned green and the fan immediately started at maximum. After about 5 seconds, the light turned yellow for one second then i heard 3 beeps and the console shut down, while the light turned blinking red.
I followed ifixit’s YLOD guide, i heated the chips with the hot air gun, i replaced thermal pads and thermal paste, but the console has the same behavior. I also tried to turn on the console without the CR battery and without the HDD, but nothing helped. What could i check or do?
Thanks!
Bu iyi bir soru mu?
Puan 0
2 Yorum
Are you comfortable with soldering SMD components?
tarafından
Unfortunately, not much. What could I have done?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The process for fixing the PS3 YLOD (Yellow Light of Death) problem involves replacing the NEC/TOKIN capacitors on the motherboard with 470uf SMD tantalum capacitors(like these). Since you stated you are not comfortable with SMD soldering, I will not provide the repair steps here.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Yes, i've seen some youtube tutorials, but i think i can't handle that. Thank you, anyway!
tarafından
Yorum Ekle
Yanıtını ekle
Alessandro sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 40
Her zaman: 1,341
