Ana içeriğe geç
XP-410, en yeni kablosuz standartlara ve Wi-Fi Direct1 özelliğine sahiptir. Ayrıca Apple® AirPrint™ ve Google Cloud Print™ desteği sunar. Dahili kart yuvaları, 2,5 inç LCD ekran ve kullanışlı dokunmatik paneli sayesinde bilgisayara ihtiyaç duymadan, çeşitli düzenlerde kenarlıksız ve kişiselleştirilmiş fotoğraflar basmayı kolaylaştırır.
How can I fix error code 0x9A
I have an Epson XP-610 that was in storage for 2-3 years. I pulled it out to see if it still works, to give to my uncle. Everything worked but it wouldn’t print - every sheet came out blank. After researching why it wasn’t printing, I determined the printer block was clogged with dried ink. Researched that and followed the procedure to put paper towel under the printer head and force water through the ink ports. Too cumbersome and time consuming. Followed instructions on how to remove the printhead and soak it in warm water to remove the ink. Took about 45 minutes to get clear water. Reinstalled the print head and when I turn on the power it says “Internal problem. Turn the power off. Error code 0x9A. Followed Epson website recommendations but nothing works. Followed suggestions made on internet. Still nothing works.
Is there any way to determine what might be causing the error? I’m pretty sure I got the wire cable back the way it’s supposed to be. Don’t know where else to look. I’m not going to take it in because it’s not worth the cost to have someone fix it. I’d like to take it on because I have nothing else to do and like the challenge.
Any suggestions appreciated.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Disregard. I purchased a new printer.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Disregard. Purchased new printer
Puan 0
Yorum Ekle
Yanıtını ekle
Jack Anderson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 32
Her zaman: 1,301
