Why does my device not lift off
All the blades spin but it will not lift off the ground
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi,
Have you checked that the propellers are fitted correctly and are in their correct quadrants?
Each blade has a number written on it. Match the blades with the corresponding number on the drone. If incorrect carefully unscrew the propeller and reposition it in the correct place.
Bu yanıt yardımcı oldu mu?
It could also be a expanding/defective battery. I’ve had a similar problem where the drone’s battery was expanding and could not supply enough power to lift off. I would find the voltage of that battery under normal circumstances and test the battery’s output. Hope this helps!
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 1,620
