Ana içeriğe geç
Nothing works on my kenmoore ice maker kenmore coldspot 106.51132210
kenmore coldspot 106.51132210 does not make ice and does not run the ice despenser. What should I check or replace? I replaced the inlet valve but that didnt fix the issue. Verified that the ice maker is on.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Was this a repair, replacing the icemaker? How old is this Kenmore? Is the icebox freezing, able to freeze water?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @adcran,
Here’s the tech sheet for the refrigerator.
Try running the diagnostics pertaining to the ice maker/dispenser functions and check for the results.
Hopefully this is of some help.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Might be broken wires that run under & inside the door. Mine has this problem. Every time you open & close the door, the wires flex, eventually breaking. Internal diagnostics don't detect this problem. You can check voltage across the main power wires (black & white) going into ice maker. I have 0 volts at ice maker and 120 VAC at the wire harness terminal under the kick plate. Wires broke off flush with the bottom of the door. Haven't fixed it yet.
Puan 0
2 Yorum:
I had the same problem with bitten wires at the bottom of the door. After fixing them, it ran for several months. Now I lost AC voltage at the connector under the kick plate. Where does this connector get voltage? Is there a fuse somewhere?
tarafından
I have a 106.517 Kenmore Coldspot and it had the same problem with broken wires under the freezer door. I repaired them and it worked for a few months. Now there is no AC voltage going to the ice maker connector under the kick plate. Is there a fuse somewhere?
tarafından
Yorum Ekle
Yanıtını ekle
Mark Cramer sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 21
Her zaman: 707
