Ana içeriğe geç
Eylül 2013'te piyasaya sürülen bir Panasonic dijital fotoğraf makinesi. Fotoğraf makinesi 60x optik yakınlaştırma ile HD video ve ses özelliklerine sahiptir.
Flash does not light up
I have a FZ72 (which is very similar to FZ70).
The flash does not work. If I open it, the camera recognises it and also preloads the flash. But if I press the button to take a photo, the picture is taken and no flash lights up.
I assume the cables could be broken, because for some time the flash only worked, if I pulled the case of it a bit backwards.
My question is, what is the tiny blue device behind the flashlight. Also there are 4 cables altogether. Which could be broken? Is it possible to fix it at all?
Resim
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @hilfs08,
Check the capacitor and the connections to the capacitor are OK. This component provides the power for the flash to operate.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Unfortunately this did not help. The cables to the flash are covered on the flash-side by rubber, so you cannot measure anything. However I tried to discharge the capacitor and it recharged after turning on, but still no flash. :/
I assume the cable is broken somewhere, but since it is tightly attached to the light itself, I would have to find a new set somewhere...
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Phil sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 8
Son 30 gün: 27
Her zaman: 805
