Ana içeriğe geç
28-84 mm eşdeğer F2-4.9 lense ve 1,0 inç, 20,2 MP CMOS imaj sensörüne sahip kompakt bir tutkun kamerası. İlk olarak 2015'in sonlarında piyasaya sürülmüştür.
How to replace the clock battery?
PowerShot G9X loses date/time each time you take the main battery out when the internal date battery has been depleted (maybe a CR1220?) Looking for instructions on where this battery is inside and how to replace it.
Bu iyi bir soru mu?
Puan 1
2 Yorum
I'm having the same problem. I Googled Canon and it says the G9X does not have a replaceable battery? Is this true????
tarafından Paylaş
Hello,
I asked Canon, and I paste their answer (in french but GTranslate will do the job for you) :
Avant toute chose, je tiens à vous signaler que cette opération est très délicate, elle nécessite la déconnexion et reconnexion de plusieurs flexibles, de dessouder l’ancienne batterie puis ressouder la nouvelle.
Il faut faire très attention ! au circuit flash (s’agissant d’un circuit haute tension, prenez garde à éviter les chocs électriques et les courts circuits avec d’autre composants).
Nous vous conseillons d’enlever la batterie de l’appareil plusieurs jours avant le démontage, pour que le condensateur du flash se décharge et de ne pas y toucher (outils et mains).
La référence de la batterie est WK1-5197-000 disponible chez notre partenaire pièces détachées https://www.eparts.fr/fr/.
They send too pictures that could help (location of the battery, tips to unmount the stuff) but I do not know how to post them.
For me I will not try the operation, but let me know if you do an succeed.
Have a nice day.
tarafından Paylaş
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
gnid @jayeff the battery is identical to a MS614. It is smaller than something like the CR1220 etc. Check the characteristics on here The Battery is readily available at online stores etc. Check this video on the disassembly of your camera.
Bu yanıt yardımcı oldu mu?
Puan 3
7 Yorum:
So, where the battery located? did you find it? @jayeff
tarafından Paylaş
Hi. The battery is located on the imaging/lens assembly. You have to take the camera apart. It's not that difficult if you know what you're doing - but keep track of where the screws go as there's different sizes and loads of them.
Please take a look at the pictures here. Remember that the replacement battery has to be rechargeable.
https://a.aliexpress.com/_mPk8lse
tarafından Paylaş
What is the type of the battery? I would prefer to source the battery before popping the G9X open.
tarafından Paylaş
I Googled Canon and it says the G9X doesn't have a replaceable internal battery. Is this true????
tarafından Paylaş
Does the MS614 battery have attached pins, or is it just the battery? Also would anyone know where to find a service/repair manual? Just for disassembly/re-assembly sake. Thanks! -brian
tarafından Paylaş
2 tane daha yorum göster
Yorum Ekle
Hi,
I couldn’t find the service manual for a G9 X but here’s the service manual for a G9 that may help.
Here’s an image from the manual showing the location of the backup battery. The Canon part number is WK1-5140-000 but searching online using the part number, indicates that it is no longer held in stock by various suppliers but can be ordered.
I assume that the battery will be the same for your model as it is a battery that is commonly used (according to the part number) in other Canon Powershot and IXUS models as well.
Maybe once you have accessed the battery, the markings on it will tell you what it is and that you can find it more easily.
Resim
(click on image to enlarge)
Puan 2
Yorum Ekle
Yanıtını ekle
gnid sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 84
Her zaman: 3,344
