I replaced the battery and still having same problem
Hello I replaced my xps 10 battery and charger. And I am still having the same problem. Power light is blinking and not powering on. Please help
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Here is an example of DELL diagnostic lights
DELL System Diagnostic Lights
The power-status light indicates the power status of the computer.
These are the power states:
Solid white Computer is in S0 state. This is the normal power state of the computer.
Blinking white Computer is in a low-power state, S3. This does not indicate a fault.
Solid amber Computer is experiencing a boot failure, including the power-supply unit.
Blinking amber Computer is experiencing a boot failure but the power-supply unit is functioning correctly.
Off Computer is in sleep state, hibernation mode, or turned off.
The following table shows different power and battery-status light patterns and associated problems
Diagnostic light codes
Amber, White Problem description
1, 2 Unrecoverable SPI Flash Failure
2, 1 CPU configuration or CPU failure
2, 2 System board: BIOS or Read-Only Memory (ROM) failure
2, 3 No memory or Random-Access Memory (RAM) detected
2, 4 Memory or Random-Access Memory (RAM) failure
2, 5 Invalid memory installed
2, 6 System board; Chipset Error; Failure of Clock, Gate A20, Super I/O or Keyboard controller
3, 1 CMOS battery failure
3, 2 PCI of Video card/chip failure
3, 3 BIOS Recovery 1: BIOS recovery image not found
3, 4 BIOS Recovery 2: Recovery image found but invalid
3, 5 Power Rail Failure: EC ran into power sequencing failure
3, 6 Paid SPI Volume Error
3, 7 Management Engine (ME) error. Timeout waiting on ME to reply to HECI message.
4, 2 CPU Power cable connection isssue.
Amber blinking? That means the power supply is good, according to DELL.
Dell XPS 18 Battery Replacement
Unplug power supply/charger. Take out the battery and and press the power button to dischage any power. After that is done, with the battery uninstalled, plug in the charger. Press power button. Does anything happen? Any flicker on the screen, beeps or lights. Describe.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 24
Her zaman: 3,696
17 Yorum
What is the exact model number?
Model Number W01A can be found by checking the device's right support foot.
What colours is the power light and how many times does each colour blink?
Same for beep codes?
mike tarafından
W01A is the model. Not blinking different colors. It just steady blinking .
Chris Nick tarafından
Not power on at all
Hi @nickel79
What colour is blinking?
mike tarafından
When I unplug the charger. The blinking stops.
12 tane daha yorum göster
