Ana içeriğe geç
GL503VM-B17N13 model numaralı Asus Republic of Gamers Strix 15,6 inç oyuncu dizüstü bilgisayarı için onarım ve sorun giderme kılavuzları.
Guide for re-pasting and cleaning
Hello,
I bought my Asus ROG GL503GE back on November, 2018. Since the last couple of days, the left CPU fan is making a faint buzzing sound, and the temps aren’t that great as those were before. I am thinking of cleaning and re-pasting my laptop. I am planning to use Noctua NT H1 for repasting.
So here are the questions:
1) Should I use isopropyl alcohol to rub off the old thermal compound? I heard some say that using alcohol might damage CPU linings (don’t know what they mean).
2) After disassembling the laptop and removing the power connector, is it a good idea to press the power button to drain the leftover charge from the capacitors inside?
3) Which order should I remove the screws from the heatsink? Are there any numberings on the screws?
I haven’t messed around with disassembling laptops that much. I would like to know the proper guide to remove various connectors inside the laptop. If there is any good thread/video about that, please share :)
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Anwarul Bashir Shuaib use this guide for the thermal paste Termal Macun Nasıl Uygulanır I would definitely perform a discharge you listed with 2. You will be okay with pretty much going in any order to remove those screws.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Anwarul Bashir Shuaib sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 31
Her zaman: 703
