Ana içeriğe geç
Apple's 2016 revision to their laptop lineup targeted at professional users. Features a 15-inch, 2880-by-1800 Retina display, quad-core Intel Core i7, 256 GB / 512 GB /1 TB / 2TB storage options, 16 GB RAM, and a keyboard equipped with a Touch Bar. Released November 2016. Features Model A1707.
260 Soru Tümünü görüntüle
Vertical lines on screen+external display stuck on apple won’t boot
No water or screen damage. Vertical lines on both computer screen and external display. I’ve tried all reset procedures. It will not boot in safe mode. Ran hardware test and it came back with no issues. Is this a gpu issue? or a kernel panic?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Can you post some pictures so we can see things. It would be helpful to see both the internal and external display at the same time (maybe a video) Adding images to an existing question
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Wow! Not good ;-{
I was hoping the issue was the display as that would need a new display.
In this case your video RAM is messed up, this will require either finding someone with deep micro-soldering skills or you’ll need to replace the logic board.
Update (02/10/2022)
Sorry replacing the VRAM is not a trivial job! You need some special tools and access to the needed parts which are hard to come by on the open market.
Here’s a view of the logic board, the Yellow marked chip is the GPU and the four green marked chips around it are the VRAM chips
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Shoot. That’s not what I wanted to hear. I took the cover off to see if I could see anything visibly wrong with a display cable or something, and randomly it started working again. I tried to pull up the errors in the console and there seemed to be a lot of gpu, and “google helper” being listed. There was a software update so I started that, and when I came back the screen was black and unresponsive. I held the power down to reset and now it’s back to the vertical lines and the apple logo. Is there instructions that I can attempt with the video ram, before i replace the logic board
tarafından
Yorum Ekle
Yanıtını ekle
Brennan Lammermann sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 339
