How do I replace my microSD card slot?
The thing just isn’t retaining my memory card, and I think it’s done for. How do I replace/repair it?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
I think you will just have to use this: Galaxy Tab 3 8.0 Motherboard
It is out of stock right now. This guide should help with that: https://www.ifixit.com/News/56864/findin...
Bu yanıt yardımcı oldu mu?
cheers m8, i have another samsung tab 3 that i could cannibalise
i just practiced disassembling it
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 21
Her zaman: 216
6 Yorum
Do you have a hot air station?
Andrew S tarafından
nope
i guess i'll just replace the motherboard
notnice -96 tarafından
i'll need to back it all up
@andrewsawesome what if i did?
@notnice -96 If you were able to find a replacement microSD card slot, you could use a hot air gun and flux to heat the solder around the microSD card slot, then remove it with tweezers. You would then tin the pads(put solder on rhe pads with a soldering iron) and heat up the board for the new microSD card until it goes into place.
Andrew S tarafından
1 tane daha yorum göster
