Ana içeriğe geç
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
F23 code - Thermistor needs replacement?
I get F23 code on my kenmore elite dryer. Code means thermistor needs replacement. I replaced it and i still get the same error code. Should i replace the whole heater assembly ?
Update (02/18/2022)
model number is 110.C87892601
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
An F23 code could also mean that there is some other problem with the outlet thermistor circuit i.e. control board or thermistor harness wiring and not just a faulty thermistor
Here’s the tech sheet for the dryer.
On p.7 Test #4a it details how to check if the outlet thermistor circuit is OK
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
i did everything, asked above. It worked for 3 cycles the the flashing pf23 code returned. this is very annoying.
tarafından
Yorum Ekle
Yanıtını ekle
simon benzekri sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 585
