Overheating and smoking after 3 minutes
Have serviced mixer but still not good. Its gets very hot after 3 minutes, can hardly touch motor casing( motor is out of the mixer)
So far I have:
Replaced capacitor
Oiled both bearing felts.
Note there is no choke coil across resistor. Can this cause issue???
Cleaned commutator in drill with 400grit silicon carbide.
Cleaned govener contacts
Used dremel to remove small amount of mica between commutator bars, they were slightly protruding.
New brushes
Checked commutator coil resistance
Screamed at the machine several times, still no improvement.
Any help on any point appreciated
Love this machine
Regards
Eric
Update (03/05/2022)
This is the electrics
Eric
Update (03/05/2022)
I'm did not mark coil housing location when pulling apart. How can I before I have it in the correct alignment. I can see a punch mark is this meant to be used to align parts.
Update (03/05/2022)
Is this an alignment mark?
Update (03/06/2022)
168 and 169 trying to align
Update (03/06/2022)
Are these the scribble line and punch mark
Update (03/05/2022)
Jayeff,
Is this the scrib line and punch mark I need to align.
Regards,
Eric
Bu iyi bir soru mu?
