Ana içeriğe geç
The Minolta X-700 is a film camera introduced by Minolta. we offer information on how to replace battery, shutter, light seal and capacitor.
Why won’t my camera turn on
Shows no life as I put battery into it
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@michellea first make sure that you have the right batteries. You need two 1.5 to 1.55 volt batteries. Make sure that you have the batteries properly inserted and that the battery connections are not corroded etc. . After that turn the cameras power switch on.
If that does not get you any results you will have to dig deeper. the error could be on the flex cable or the PCB. For that repair you do want to go ahead and use the Minolta X700 Service Manual
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
@oldturkey03 - Love the mask!
tarafından
Yorum Ekle
You'll need to check the battery compartment to see if the contacts are corroded.
Puan 0
Yorum Ekle
Check corrosion on the battery door/cap even if it doesn’t look corroded clean with vinegar.
Source: worked with mine
Puan 0
Yorum Ekle
Yanıtını ekle
Michelle sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 15
Son 30 gün: 56
Her zaman: 3,540
