Ana içeriğe geç
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Soru Tümünü görüntüle
Soru Kapandı
Keyboard Backlight Problems MBP17 Unibody
Hi I have two Unibody MBP17 a matte and a glossy screen, I changed out the two displays and has a keyboard light does not work both PLEASE HELP!!!!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
Have same issues with my A1297 MacBook Early 2009 MacBook Pro 2,66 GHz
After changing the uppercase my backlight does not work properly!
I noticed, that covering the sensor near the camera turns the keyboard backlight on,
BUT I CAN'T CHANGE THE BRIGHTNESS (NO F5 AND F6 BUTTON WORKING!)
Cable was checked and is connected.
Does anybody have any suggestion, where the problem could be? When i push the button, it's greyed with a prohibitory sign...
Any idea? Thanks in advance!
== Update ==
Problem solved: Covering the light sensor next to the camera --> f5 f6 work (dark)
if it's bright outside --> f5 f6 are disabled
Thank You anyways
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Try resetting the SMC.
tarafından
Yorum Ekle
hard to pinpoint i need pics of it
Puan 0
Yorum Ekle
What kind of picture? Both of them is the same type MBP17 unibody 2.66 ghz/ both of them are working perfect after I changed the displays the keyboard back light is not working
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 1,377
