Ana içeriğe geç
Soket 1366, ilk dönem Core ve Xeon serisi işlemciler için tasarlanmıştır.
Does resettable fuse has direction?
Hi, Does resettable fuse has direction of installation ? Thanks
Resim
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
No, resettable fuses do not have a polarity.
Bu yanıt yardımcı oldu mu?
Puan 5
1 Yorum:
Thank you 🙏 🌞
tarafından
Yorum Ekle
no
”Comparing PTC fuses to one-time fuses Every fuse has an amperage rating and protects downstream circuit components from damaging overcurrents. Both one-time and PTC resettable fuses connect in series with the load and are not polarity sensitive. PTC fuses reset themselves, whereas one-time fuses open the circuit as a one-time positive disconnect and must be replaced before resuming operation. Both technologies require the removal of the overcurrent condition to resume normal operation. Due to this key characteristic, selection parameters differ — some of which are compared in Table 1.”
https://www.eaton.com/content/dam/eaton/...
Puan 2
1 Yorum:
Thank you sir!
tarafından
Yorum Ekle
Yanıtını ekle
Formingus sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 1,004
