Ana içeriğe geç
Apple's 2016 revision to their laptop lineup targeted at professional users. Features a 15-inch, 2880-by-1800 Retina display, quad-core Intel Core i7, 256 GB / 512 GB /1 TB / 2TB storage options, 16 GB RAM, and a keyboard equipped with a Touch Bar. Released November 2016. Features Model A1707.
When opening Monitor the screen is blurry and computer non-responsive
When I shut my MacBook Pro for a while and then open it back up, the screen is blurry and computer is non-responsive for a minute or so. Then it gets happy and works perfectly.
It I don’t move the hinges the computer works perfectly. I took it to Apple and it passed the diagnostic tests but the repair estimate was pretty high.
Is it possible there is a loose wire ?
thx
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
A loose wire wouldn't do that. A failing component would.
So if you plug in an external display via the Thunderbolt port (USB-C) when you encounter the issue is the external display showing the proper image Vs the internal? If thats the case the internal display assembly has the issue. If the problem is present on both screens the main logic board has the issue. Both parts are not cheap.
OK, can we dive deeper fixing something deeper. It might be possible, but that will need deeper skills and proper tools to to the task not something a DIY person can do on their own.
Think it this way a GP doctor is not a brain surgeon and you would need the skills of brain surgery to go deeper!
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
I left the computer connected to my external monitor, shut the lid, and then when I opened the lid only the laptop monitor was fuzzy. The external monitor is perfect.
thx
tarafından
@cmd41par - Good so we know the issue is within the internal display logic (T-CON board). Sadly you can't replace the T-CON, but you can replace the display assembly! But supply of displays are very tight ;-{
∙ 15" MacBook Pro Display Assembly - Space Grey (16/17), Apple P/N 661-08030
∙ 15" MacBook Pro Display Assembly - Silver (16/17), Apple P/N 661-08031
Here's the guide to replace it MacBook Pro 15" Touch Bar Late 2016 Screen Replacement
tarafından
Yorum Ekle
Yanıtını ekle
chris sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 26
Her zaman: 618
