Ana içeriğe geç
Why does my pc shut itself down after 10min
So I have had this custom built pc for about5 months and now after 10 minutes the computer randomly powers off. When this happens lights are still on in the back so the pc is getting power. And all the fans are working and are clean so I do not know what the issue could be.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Could you use hwmonitor https://www.cpuid.com/softwares/hwmonito... and take a picture and/or list of the temps? Celsius is preferred.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
It sounds like it could be a malfunctioning fan on the power supply which is causing the power supply to over heat, which can cause a computer to shut down unexpectedly. maybe get the power supply tested, and if it is faulty i would strongly suggest replacing it asap. because it will start to damage other components of the PC and can become costly to fix.
And if the power supply is working 100% then the next possibility is either, issues with a driver and or malware and for that i would suggest running a diagnostics on your pc and take it from there.
I hope this helps you in resolving your problem and please let me know of the outcome.
Thanks
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Mine was doing the same thing. I believe since I have CRS disease, that I tracked it down to the BitDefender AV I was using.
However, the point is that an app can cause that problem, so if the temps are not causing the CPU to shut down, start eliminating apps by turning off all none essential.
Puan 0
Yorum Ekle
PC on but 5 minute before off
Puan 0
1 Yorum:
Why this post?
tarafından
Yorum Ekle
Yanıtını ekle
Malcolm carney sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 25
Son 30 gün: 191
Her zaman: 1,619
