Ana içeriğe geç
Ice build up around compressor
the unit is cooling properly but ice is building up around the compressor
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @sandg ,
What is the model number of the refrigerator?
It could be a number of things e.g. clogged condenser coils, faulty defrost system etc.
You may have to relocate the contents of the refrigerator so that it can be turned off to allow the ice to melt so that once it has all melted away you can see where it starts to ice up when it is turned on again.
Also check inside the freezer compartment for ice build up on the evaporator unit. Remove the panel inside at the back of the compartment to expose the evaporator unit and the evaporator fan. Access is through the door at the front.
If there is ice build on the evap unit, do not use a hair dryer on hot to melt it as you could damage it as it is used to operating at temps below freezing. Allow the ice (if any) to melt naturally aided occasionally by using a hair dryer on the coolest setting for only a short while to speed things up a bit.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Louise Leho Edwards sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 1,254
